Find intersection points between multiple curves on a spheric surface
Hi, I got a new question: I’m trying to sort a set of points ( 4 points per curve) along a set of curves (5 curves) which results in 20 total points.
The set of points derives from the curves (points are constructed as a result of crossing of planes and curves as you saw previously) and there are no other points on this curves.
The problem is that in trying to sort them whit the sort points on curve command, instead of getting 5 blocks with 4 points per block, I get 5 blocks with 20 points per block ( and some of them are repeating in the list)
Could you explain me how to fix this?
without your file? no.
