Filleting more than one corner at a time
Say I draw a rectangle and want to fillet all of the corners the same radius. Is there a way to just with 2 clicks do all of the corners at once?
enter the command option ‘rounded’
For any sort of curve with kinks you can fillet all the corners at once using _FilletCorners. If you have small segments in the curves near the kinks that will be “eaten” by the fillet, there may be some failure cases, see this thread…
–Mitch
