Filletedge the object failure
Any idea why I can not filletedge the object? How can I solve it?
Presentation1.pdf (530.4 KB)
t-1.3dm (9.2 MB)
Thanks
the edges are not tangent at (x)
and the angle of 1.5 degree is close to document tolerance.
use _gcon to meassure
Command: GCon
Curve end difference = 0.007 millimeters
The radius of curvature difference cannot be calculated.
Tangent difference in degrees = 1.549
Curve ends are out of tolerance.
redraw it
the box - precise:
_length and _radius to figure out dimensions
_box - with input of dimensions for precision
the box quick and dirty
_boundingbox
the fillets
_filletEdge R9.250
_filletEdge R1
EDIT:
is this what you re after ?
… done with the fast boundingbox-approach
t-1_tp.3dm (6.3 MB)
hope this helps - kind regards -tom
