In this object to the fillet it is really complicated! We must lower the tolerance, and the edge of the red fillet can not be executed properly. It will be a bug?
Check please.
problem fillet.3dm (129.1 KB)
Check please.
The object has edge tolerances larger than the (large) file tolerance. Edges are no where near the surface… not much chance of working, I would say - much better to build the object cleanly before attempting to fillet.
Thanks Pascal, but I tried with different tolerances. The fillet has already been executed, for example, only works in 0.1, if I decrease does not work anymore.
Here’s how that corner looks of the existing surfaces have their edges rebuilt:
