Hi all,
is there a way to make a solid fillet between faces and edges?
thanks
Dear @nicola.ss4
the fast answer - there is no single command that can do this (as fare as i know)
you search something like a variable fillet ( _variableFilletSrf and _filletEdge with multiple handles) - but both functions do not offer an advanced way to influence how the fillet-Radius is interpolated.
I love the idea of a command that allows to create a fillet, with a starting, tangent edge - and a target surface.
you will need a cone surface
(brown)
and some transitions inbetween:
fillet_edge_to_srf.3dm (348.9 KB)
the workflow i used:
to construct the parts of the cones:
duplicate the planar surfaces and “fold” them down.
_extractSrf
_orient3Pt
now you can construct starting and end _arc
_arc Tangent (arc tangent two curves)
→ a bit tricky to get
_loft the blue arcs to get the brown cones
for the violet transitions - i did a
_blendCrv (tangent) for the missing edge
and a
_sweep2 (rails are the edges of the brown cones, “tangent” )
Hello- not as a solid operation but the test command testFilletSrfCrv may get you there - it is a test command and not supported - i.e. ‘use at your own risk’.
Note it does not always, at the moment, make the sweetest fillet surfaces…
testFilletSrfCrv_TEST_00.3dm (111.0 KB)
dear @pascal can you give more hints how this (nice) testcommand might work ?
did not manage to create any useful surface.
thanks
An old workaround was this:
Drawins a pipe around the edge/curve. ( orange in the section )
Offsetting the surface by the pipe radius. ( orange )
Filleting with radius decreased by pipe radius. ( green )
Offsetting back the resulting fillet surfaces again by pipe radius. ( red )
Non fast, obviously, but might be useful if you have to draw only few fillets.
HTH
Hi Pascal,
Huh …
I remember that (test) command … but not when it appeared. ![]()
Was it Rhino 5 ?
Or maybe earlier ? ![]()
Thanks to all for the replies!!! ![]()
The test command _TestFilletSrfCrv make the job, also because I was looking for a command that make a costant radius.
I think it could be usefull if it became a real command, with the possibility to select a chain border.
Many Thanks again!
