Hello All,
I got am issue with fillet edge command. When i use the commend and try to do fillet edge it is giving me error. I have attached the rhino file as well. please suggest.
P0801.3dm (661.9 KB)
Hello All,
Hi Neha - I see this, thanks. If you do all the edges at once - all the way around, it does trim properly. I’ll get the failure on the list - if you just want those edges filleted, and need help getting it done, shout.
RH-74101 FilletEdge - trim failure
