I’m new to the forum and fairly new to Rhino. I’m attempting to fillet the edges on a hull I am modeling and keep running into difficulty in getting satisfactory results with this command. The intersections at 90 deg. all work out fine, but the intersections on the hull( outer and inner surfaces ) are not filleting properly. I’ve tried rebuilding the surfaces, doing the larger fillets first and lowering the absolute tolerance a bit, but to no avail.
Can anyone explain where the problem lies, and what’s the best approach to solving it? I’ve attached the file for your review. Thanks for any help and I’m glad to be here! 8’ Dinghy.3dm (1.4 MB)
The inside and outside corners of the hull, where the vertical corners meet the top surface is the problem area. Also, the corners of the keel at the ends. Thanks!
All the fillets look great! Thanks for the help! I’ll try simplifying the surfaces a bit more and see what I can do. I didn’t think to try the FilletSrf command. We’ll test my deftness with the surgery.
