Fillet a variable radius interior corner?
Coming from Solidworks where this operation is automatic, I am not sure how to proceed. I tried using TestFillSrfCrv (‘Test’ since I’m still in 7 not 8) but it doesn’t have the desired effect. I got something like what I want but not quite.
what I want:
nearest I can get
TI84 battery plate stand.3dm (6.2 MB)
If you fillet the vertical edges of the teal solid first–you’re going to have a fillet on those, right?–you can wrap the fillet around that easy enough.
You’re right, I should. Could you describe how you created the geometry in your photo, once those teal corners are filleted?
Well I was trying to get something out as quickly as possible so I just booleaned the large objects and used FilletEdge. I usually build all my fillets ‘manually’ with FilletSrf.
Wow, I have tried before on other models, but it never worked so I just assumed interior fillets worked differently in Rhino. This is just what I wanted. Thank you!!! And for such fast replies. You rule.
