hello everyone,
I wanted to know how to retrieve the data from an autosaved file
the rhino crashed, although the file got autosaved and it’s showing the size as well that means it’s not empty, however still the file is showing no objects with empty layers, please help
Hi -
4 MB is very little and can very well be other things than geometry. Run the Audit
command to see what’s in the file.
Also, if you haven’t changed the default settings and did save the file at least once before it crashed, there should be a *.3dmbak file in your folder.
