As a soon 12 month user and soon to be a launched site with Shapediver i have gathered some feedback and suggestions on Shapediver
An amazing software overall!
Allow empty inputs in the app/app builder - I work mostly with millimeters between 0 - up to 12 000mm, and mostly with slider inputs (The customer can see the limitations with the slider) and customers will mostly use the number input field due to the large numbers. And I want it to be mobile friendly which the app builder is, but when you erase the preset numbers in the input field a 0 turns up. And when you put in a wanted number like 2500 that 0 adds on so you put in 25 000 instead if you are not awake as customer. Solution would be to allow it to be empty and adress a warning or something instead. I havenāt seen this problem testing the products in Shapediver, only app builder.
Desktop connection to GH/If not possible change the GH file and keep the ticket - As adressed in this thread: Updating a model? . We will start with around 10-20 products and growing from there with Shapediver hopefully, now when Shapediver is taking a real step into ecommerce with own integrations this should be prioritized. This is not so big issue when having 1-2 iframed configurators on a website, but with 10-1000 products integrated to Shopify/Woo this becomes a real big issue not be able to make small changes to the models without having to reupload an updated model and change tickets. You loose cache and its a big workload and it opens up for mistakes.
Make inputs and outputs specially for pricing in GH to clear cache - With the existing shopify integration you use the Shapediver Direct Data Output to send the calculated price to the integration/Shopify, I dont know how the new integration will work, if its something like the existing new outputs/inputs should be made for pricing only that lets you clear the cache on the price only and keep valueble geometry/input cache.
