Feedback on PC build - swap 2080ti for the quadro rtx4000?
I placed an order for a build with a 2080ti, i9 9900k and a 27” Benq monitor. I’m hoping this is a good build for my purposes of rhino 6 and rendering vray or keyshot for at least 3 years of heavy usage. I can still amend some parts if I let them know by tomorrow so if there’s a very good reason to change something, would appreciate the feedback. Have read on some other threads that the quadro is better for rhino… and could get the quadro rtx4000 for a bit less than the 2080ti. (But the comparison doesn’t look good: https://gpu.userbenchmark.com/Compare/Nvidia-RTX-2080-Ti-vs-Nvidia-Quadro-RTX-4000/4027vsm716215)
What do you think?
Thank you.
Here are the parts: https://ca.pcpartpicker.com/list/cGZWxG
  • CPU: Intel - Core i9-9900K 3.6 GHz 8-Core Processor ($629.99 @ Mike’s Computer Shop)
  • CPU Cooler: Corsair - H100x Liquid CPU Cooler ($109.99 @ Newegg Canada)
  • Motherboard: MSI - MPG Z390 GAMING EDGE AC ATX LGA1151 Motherboard ($239.50 @ Vuugo)
  • Memory: G.Skill - Ripjaws V Series 32 GB (2 x 16 GB) DDR4-3200 Memory ($185.99 @ Newegg Canada)
  • Storage: Western Digital - SN750 500 GB M.2-2280 Solid State Drive ($149.99 @ Canada Computers)
  • Video Card: EVGA - GeForce RTX 2080 Ti 11 GB Black Video Card ($1439.99 @ Mike’s Computer Shop)
  • Case: Corsair - SPEC OMEGA ATX Mid Tower Case ($94.99 @ Canada Computers)
  • Power Supply: EVGA - 850 W 80+ Gold Certified Semi-modular ATX Power Supply ($165.04 @ Amazon Canada)
  • Operating System: Microsoft - Windows 10 Home OEM 64-bit ($128.50 @ Vuugo)
  • Monitor: BenQ - PD2700Q 27.0" 2560x1440 60 Hz Monitor ($415.83 @ Mike’s Computer Shop)
  • Keyboard: Corsair - K55 RGB Wired Gaming Keyboard ($67.99 @ Newegg Canada)
3 year warranty through memory express: $486
Build: $75
Taxes: $500
Total: $4760 (Canadian)
The Ryzen 12 core 3900x is due out this month. I’d hold out for that. I’d also hold out for the RTX 2080 Super which is also out this month. It’s rumored to be just as a powerful as the old 2080 ti for the cost of the non ti.
I would wait a year until Intel Xe GPU is out with 5X the performance of the 2080 Super.
I am sorry, but the main office called, and they need you to send me that machine immediately after it comes in : )
Well, if you wait 6 more days, AMD might have a cheaper CPU, by some $229.
Nice inexpensive case, so that money can go toward the parts. Good memory. I might go with a Big Nactua Fan Cooler because it’s simpler, although a heatpipe/heatsink cooler is heavier on the motherboard. I prefer Corsair power supplies because mine lasted 7 years, so far, unless you can afford Seasonic. I hope that monitor has pretty accurate color for that size/price.
My MSI motherboard also lasted for 7 years, though I might check the UFI/CMOS version, to make sure there the firmware has no must-have updates.
Nice stuff.
This is the best comparison I could find on nVidia performance:
So in some CADs the Quadro rules, but in Max and Maya they don’t. And the 2080 has 2x the cuda cores, important if cuda rendering is part of your thing.
As always with upgrades the best advice is “Wait”!
I’m mostly going to do work in rhino 6 with the vray next plug-in and possibly keyshot. Some photoshop as well. Is the rtx4000 a better much better performer for rhino 6 with vray compared to 2080ti? Any way to confirm this without buying both cards and running tests?
Thanks Brenda. I have a liquid cooled Corsair specd which I hope is fine. The monitor is sRGB.
This answers my question: https://www.youtube.com/watch?v=2JmWrO2bcsQ
2080ti it is hands down!
Seems like a broad and thorough test, so good luck and thanks for sharing your finds.
I’m using 1080Ti and I pretty happy with it combine with a 4K resolution.
You can purchase one or two used at this point.
So the 2080Ti is OK but
most important is a big 4k 144Hz monitor to look in to the curve shape. Then the GPU that can push and handle that.
I use curved 48 TV (because is what I was able to afford in this country). But is much better a 144Hz monitor so that you can stay more time in front of the monitor. To push that amount of pixels or refresh rate a 2080 Ti is good. The 2080Super is similar in frame rate to 1080Ti and also are OK (to consider).
The old and used 1080Ti is a bit more powerful (in FPS) than the new 2080 Super. So consider upgrading your 400u$d monitor to a 4K 144Hz. If you purchase a small 4K monitor you will need to exand the icon size and font and that is not good (is worthless). A big 4K TV at 60Hz can give you nausea after 7hs of work.
from: https://www.adslzone.net/2019/07/02/nvidia-rtx-super-lanzamiento/
from: https://www.notebookcheck.net/NVIDIA-RTX-Super-specifications-leak-RTX-2080-Super-touted-to-be-faster-than-the-Titan-Xp.426571.0.html
Maybe a lame question (or misunderstanding of the problem), but:
What is more performance expensive for the viewport?
  • Running Rhino on the higher resolution like 4k instead of 1080p or 1440p
  • Increasing antialiasing settings?
I’m interested in this question. There seems to be NO or very little information around that directly compares ‘consumer’ grade GPUs with pro grade ones.
Some people say that pro GPUs are better for CAD and 3D modelling although I’ve never seen a strong argument as to why other than ‘driver optimisation’. My suspicion is that much of it is a con by nVidia and AMD to sell essentially the same gear at vastly inflated prices.
It would be really good to have some end user generated benchmarks of performance for different GPUs on PC and Mac.
Well the short answer is the differences are becoming less relevant as time goes on, it is a bit of a “market differentiation” ploy. You can Google benchmarks comparing any card to any other these days, there is no reason to debate. My general advice is to only buy the absolute top end of “pro” products, they might not be much faster but if you can afford to pay 3 times more for 10 percent more speed, go ahead, makes more sense than paying about the same for less performance under most situations.
The userbenchmark website is the best I’ve seen but it does seem to be focussed on gaming. It would be really good to have something primarily looking at OpenGL, GPU raytracing etc.
Maybe I’ve missed something but I do periodically check.
Jumping from 1080p to 4K is like having 4 monitors 1080p push by one GPU.
So if your geometry is becoming complex as for example you will have frame rate problems rotating in perspective.
Depend on the antialiasing type. There are a lot of different types. You can customise it in Window specific for Rhino. If It is a fast good simple antialiasing can just pick up 20% of performance. If It is an old type, x2 can be like having 4 monitors and rendering that into one monitor. X4 X8 is expensive in that case. So your frame rate can decrease x2 x4 x8.
Usually, the monitor is fixed to 60Hz. But the rotation of the object can decrease. Under 15 FPS frame per second or in this case rotation per second is not good for inspecting the object. More post process you add as for example Display Pen or Artistic more GPU power you need. Also using Rendering with lots of big colour 4K textures can eat GPU power.
Monitor example screenshot: Rhino running at 768p with X4 antialiasing is not the same as a 4k without.
768p left and 4K on the right
