Hi team McNeel,
if possible, can you think about adding a parameter to set the viewport display of sun On/Off in Sun Preview component, as it hock a lot of resources when using it to display many sun positions. Attach screenshot of native node vs that of LadyBug. In most case people just need the direction vector. Even without the SunPreview node, just converting the Rhino Sun to a vector is ~4x that of LB.
Or better, just add a vector direction output to Sun component.
Just a thought for consideration
