I have a request for a (small) feature within Shapediver:
It would be helpful to be able to reverse the direction of the auto rotate in the viewer.
If it would be possible to change the direction text on all vertical cylindrical objects would be better readable, because the object would turn into the direction one proceeds to read the text.
Sounds like a reasonable request! We are getting ready for a big update of the viewer at the moment, and that’s a small item to add to the list. How about a viewer setting that allows to switch the rotation direction?
Viewer settings to change the rotation would be great. When can we expect the viewer update?
We should be able to add it within the next two weeks. I’ll make sure to post here when it’s available.
@scherzer I just stumbled on a model with a similar problem than yours and remembered this topic. My apologies for never posting an update, but I can confirm that it is now possible to set the rotation direction. The “Auto Rotation” viewer settings now accepts negative and positive values, the sign determining the direction of the rotation. I hope that feature is still relevant to you!
