Feature request (pattern select)
simple task in GH, but this would speed up workflow in Rhino tremendously.
select a pattern > hit hot key (up arrow key for eg)
selects the next possible point in the pattern
Hello - you can try this plug-in - I’m not sure it gets all cases right but it may be a start
SelPointPattern.rhp (13.5 KB)
You’ll need to un-block the rhp file in it’s Properties and then drag and drop it onto Rhino. The command is
SelPtPattern
Awesome!!! u rock @pascal !
