Feature request - matching a curve on both ends without breaking history
Working on many profile curves for a series of grips, adjusting the curve’s form by noodling its CPs after matching on both ends is tedious - matching one end of the curve breaks the history of having matched the other end.
How about the Orient? and for your reference.
Hi @jessesn
I think that what @Lagom is talking about is this:
A curve only being able to retain the match of a single end, whereas surfaces - using MultipleMatches - can retain multiple. It’s basically what Blend already does (via the Edit function), but with a curve of your own choice. I agree that it would be a very nice addition to the Match command.
-Jakob
That’s not what I mean, please see below. I need to Match curves on both ends with history, like in “other software”, so that while manipulating the CPs, the continuity established on both ends is not lost.
Yep, that’s exactly what I mean - matching a curve on both ends without breaking history when you then manipulate the CPs. No problem in “other software” ; )
Understood, thank you for your feedback. I’ve submitted a request to our development team.
RH-99070 Match: Add a MultipleMatches option
