I just discovered this setting for “Links” in Navisworks, and immediately my thought was how I wish something like this could be applied to Annotation Dots in Rhino.
The core function is:
Elements greater than [specified distance] from camera area automatically hidden. Elements are dynamically revealed/hidden as the user moves the camera.
Links in Navisworks have a similar display behavior to Rhino dots in that they maintain a consistent size on the screen regardless of zoom level. The Cull Radius setting allows there to be many many links present in the model without overcrowding the viewport.
In Rhino, I think something like this would need to be easy to toggle on/off on the fly, but it would it would be super useful. I often will populate a model with a large number of dots via grasshopper for the sake of making some information highly visible. The trouble comes when trying to zoom into a particular location and things become difficult to read due to dots in the foreground and background overlapping. Can be navigated with clipping planes somewhat, but I would love a more fluid solution.
Also would be great if it applied to grasshopper preview of dots as well
Currently, my ‘solution’ is often to create both dots and text objects for the same info, so I can have information visible at a zoomed-out scale with the dots, then turn off the dots and use the text objects when I need to get up close.
Downside here is I have an issue (maybe Rhino.Inside Revit specific now that I look at it) where text masks seem to be fighting with the text for draw order, but I suppose that should be an issue for another thread…
Anywho, thank you for you reading, interested in folks’ thoughts!
