Feature: Add Sorting for Key and Value columns in UserTextAttributes window
Hi McNeel Team,
Can you please add sorting to the UserTextAttributes Window in order to sort keys (in Key column) and/or values (in Value column) by name?
See below:
That would be very valuable.
Thanks,
Dmitriy
Thanks @Dmitriy
I have created a request item here for the issue.
https://mcneel.myjetbrains.com/youtrack/issue/RH-45092
You have no permissions to view this page
Hi @Trav
You might want to add this topic to it:
Sorting Attribute User Text
Thanks Willem
@Willem Added! Thanks, I had missed that post!
Can the Sort option also be added to the Text Field?
Hi Kevin - I’ve put that request on the list as RH-57510.
Thanks,
Hi Wim, A quick thanks for your work + effort.
I see where the Sort option could also be helpful for sorting certain Document Properties in the Options menu (Hatch types & Linetypes).
These are options I am defining in the creation of an office template.
_K
Hi Kevin - that feature request is now on the list as RH-57577.
RH-57510 is fixed in the latest WIP
