Failure in duplication of display modes
Hey, I just wanted to report that when you try duplicate a display mode that has its own unique options (like monochrome) rhino 9 will duplicate it as a default display mode without any of extra options. This is not the case in rhino 8 and I was wondering if there is a workaround for it. Thanks!
I’m not seeing that here-
are you modifying the default then copying it or copying it first then modifying it?
Copying first then modifying it. here an example. For instance, here they dont have the same visibility settings.
Hi Biskiwit -
This should be fixed in an updated WIP.
