Failed to fetch packages from source(s) - Cannot access a disposed object
Continuing the discussion from Help: Vectorize image in v7?:
Hey @encephalon, I wanted to follow up on this without derailing the conversation away from the Vectorize plug-in.
Do you get the same error every time you run the _PackageManager command?
What happens if you run the command below on cmd.exe?
"C:\Program Files\Rhino 7 WIP\System\yak.exe" search --all
hi Will, sure no problem! thanks for responding.
yes i get this message each time i run the command. i am on a mac to point that out again. also not sure where to run cmd.exe?
Whoops, the equivalent in macOS is to open the Terminal app and run this command instead…
/Applications/Rhino\ 7.app/Contents/Resources/bin/yak search --all
Hit Enter to run the command.
I’m hoping to narrow down the problem by seeing if you can query the server outside of Rhino.
yup seems to work, it starts listing the packages.
AMDDenoiser (0.4.1, 0.4.0, 0.3.2, 0.3.1, 0.3.0, 0.2.0, 0.1.0)
Autozoner (1.0.3, 1.0.2, 1.0.1, 1.0.0)
Biomorpher (0.7.1)
bookworm (0.6.1, 0.6.0, 0.5.0)
Bubalus_GH2 (2.0.1, 2.0.0)
Clipper (0.3.2, 0.3.1, 0.2.11, 0.2.7, 0.2.6, 0.2.5, 0.2.3)
Cockroach (0.0.1)
CockroachRhino6 (0.0.1)
ColorPicker (6.0.0)
etc.
Thanks. One more idea…
Can you try running the scripted version of the PackageManager command, _-PackageManager, and then click “Search” and enter “Vectorize” as the search term? This causes the package manager to query the server in a slightly different way.
At any rate, I think I might have to get Rhino to display some more information about this error when it occurs so I can figure out exactly what’s going wrong.
nope sorry negative. i followed the helpfile and had tried that already, now trying once more i have to confirm it does not work. it brings up the same message and quitts the command after pressing ok.
Thank you for trying. I’ll add some more diagnostic information to Rhino to help track this one down, hopefully this week.
Until then, if you’re still interested in trying the Vectorize plug-in, you can install it using the CLI by running the following command in Terminal…
/Applications/Rhino\ 7.app/Contents/Resources/bin/yak install vectorize
Hi Will,
I’m using a Windows 10 PC, and just now running into this issue, as I was trying to vectorize a “scalar figure” (essentially a .png silhouette of a person that is solid hatched, if it helps). I need to Make2D of a view, and realized the .pngs didn’t show up. Read somewhere on here that Make2D only pays attention to curves, not pictures.
I came across this same error when I tried to use Vectorize today via -_PackageManager, tried the alternative you suggested via command prompt, and no dice. Wanted to know if there were any other available workarounds?
Hi -
Please run the Rhino SystemInfo command and copy-paste the result here.
Thanks for the reply, @wim. Usually reviving a forum post months later results in no responses:)
System Info:
Rhino 7 SR10 2021-9-13 (Rhino 7, 7.10.21256.17001, Git hash:master @ 68677dc86520a0de9485d8b8fa2e841e757733f3)
License type: Educational, build 2021-09-13
License details: Stand-Alone
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 7.9Gb)
Computer platform: LAPTOP - Unplugged [83% battery remaining]
Primary display: Intel(R) HD Graphics 630 (Intel) Memory: 1GB, Driver date: 2-28-2018 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1050 (NVidia) Memory: 4GB, Driver date: 6-9-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.80
> Integrated accelerated graphics device with 1 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-9-2021
Driver Version: 27.21.14.6280
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 4.27.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.10.21256.17001
