I made two models form YouTube,
one: was making a random size shapes patterns with different extrusion
second: was making a pattern that gets smaller to its when its near the point.
I’m trying to mix both into one: I want to extrude the patten randomly or when its near the point its smaller.
my problem is when surface is like a (n) and when I try to extrude it, only one side of it will move not all of it like as its one piece
as you see the picture below a view from the top and when I extrude only the surface facing south will extrude without the sides on the left and right, it should extrude like an offset continuing the design flow as a one piece. the extra curve are just some experiments.
right now I added a command called face to face offset using the same componints and that kinda helps but now I feel more stuck as I can’t control the distance, dunno how to make it random, it doesn’t not flow as one piece.
(in a way I want to take the settings from the random triangle extrusions and add it to the facade design)
thanks Vikthor that’s what I needed.
I also have another question, when I bake it is their a way to make it run smoother? a lot of pieces means slow pc.
