I made a simple script to model rectangular panels on a surface. However, like the attached picture, I wanted the panels to run along the side I called “X” not Y. I tried a reverse surface direction and nothing happens. Any suggestions?
IS there any way I can also insert a small gap in betwwen the tiles too? I tried offset curve and extude but that doesnt seem to work (so that the gap does not extrude solid)
i’m not sure I understand, you want the panels as solids but also the gap as a solid?
no, I want the gap as a void that doesnt extrude and the tiles as solid. Also, I dont think the reverse surface direction worked. It still is going the same direction
there you go, I added also the gap as a surface.
Double click the toggle to swap the surface’s directions
offset.gh (9.8 KB)
hi ! thank you! that works, but, I cant seem to get it to extrude ? and I just swapped out your rectangle so that it uses a surface to reference . Is there a way to change the offset distance too?
and how did you get it so that the gap isnt modeled as a surface? I wanted to figure that out!
thanks!
I offseted the panels in both inside and outside. I sort them by perimeter length, and take the smallest one.
To extrude more, hover your mouse over the “F” input of the Z axis component. I’m pretty sure it asks for a number as length !
well, I got the offset and UV direction swap to work! I just modified your script slightly. However, Its giving me the error message on the Boundary " All curves failed to load" and “Planar surface routine yielded no results”. And it still wont extrude? I’m confused as to why that is because
I gave it a number in the Z factor. I’m not sure how to fix this!Hey !
I think you could spend a bit more time searching here… I’m at work
I see you changed the B input of the offset component, I don’t think there is any reason for that.
Also, change the value in the D input of the same component (after reading what it is).
If you fix theses, no need for the cap at the end.
also you forgot the output O of offset component. Has to be connected to the A input of the sort component.
I gave you the definition (the grasshopper file) at the very beginning of the discussion…
Why not use it?
