Hi guys,
I am trying to extrude the 2 profiles having 2 rails but the extrusion direction might be an issue? the direction of extrusion looks like it is twisting? any idea? thanks
try to reverse / flip direction of one of the sections.
post the .gh file with internalized geometry if you need more help.
it s a sweep2 - not a extrusion.
Hi Tom,
Thanks for your help, yes, I did used the flipping curve, but I think the issue is the order of points of the two profiles need to match-up so that it will extrude on a correct direction. Please refer to attached files below, cheers.
Profiles extrusion.gh (30.2 KB)
Profiles extrusion.3dm (103.2 KB)
Thank you Jessesn, I will give a try
, cheers
Thank you Jessesn, l will review the gh file, cheers.
