How do I structure the Direction parameters for ExtrudeCrvTapered?
In my RhinoCommon plugin I’m sending the command:
“_-ExtrudeCrvTapered 2 _DraftAngle=2 _Solid=_Yes _Corners=_Sharp _DeleteInput=_Yes _Enter”
to RhinoApp.RunScript() and I’m getting the response:
Command: _-ExtrudeCrvTapered
Extrusion distance <1> ( Direction DraftAngle=2 Solid=Yes Corners=Sharp DeleteInput=Yes FlipAngle ToBoundary SetBasePoint ): 2
Command: _DraftAngle=2
Unknown command: _DraftAngle=2
It seems I need to supply a defintion for a direction vector but anything I put ahead of the DraftAngle parameter causes an “Unknown command” response. I’ve tried lots of variations of _Direction parameters without success for defining a direction vector.
The syntax example would be appreciated. I’ve not found an example in my searches.
Thanks,
Bob
