Im pretty new rhino user and i come across one thing that bothers me a bit. I would like to be able to extrude a surface of a solid so that the surface grows or shrink in line with the adjacent sides. Im an architect so I draw slabs a lot. In archicad that I used earlier this was a breeze, but do someone know if there is a simple way to do this?
Waht I do now is that i first extrude, then I have to move the vertical edges out in line with guidlines of the adjacent sides. Se picture.
Extrude is the wrong command for that.
I would try a 2d Scale using a back corner as the base point.
Rhino 8 is able to do that with Push-Pull modeling.
https://www.screencast.com/t/qxSacXyNTaaR
(the clipping you see in the viewport during the preview is already fixed in the current WIP)
Ah thanks, that worked, at least for this triangular slab. But it does not seem to work when its more sides involved, at least not in the way I would want it to.
Good news!!
