But just a question : how did you create the profile ?
i tried to extrude the curve… it’s not that … i tried to revolve , but the arc is not uniform so it’s not ok neither. i know it seems easy but for me everything seems complicated !!
Thank you !
first I used _Rotate to put your profile curve on the green axis then _Offset -> Through Point using the corners of the flat plane as the points… the inner offset ends up too long so I Trimmed it… the outer offset ends up too short so I used _Extend on it… then added the little straight lines at top and bottom then Join and Revolve.
all that aside, if I were you, I’d avoid doing all that and redraw the profile fresh. or draw the outer surface profile then offset it inward.
