Hi, in this analyzed grid, I want to extract, deformed curves from the beam view to do more implementation on it. But, as you see, the curves option is null. Please help me to extract these deformed frames as curves, not mesh.
Best Regards.
Lazan
Triangle curve.gh (83.2 KB)
Hi, you can use the modelview to extract the deformed curves
its the defAxes output - the curves are found there. However you need to make sure the Elements in ModelView are activated.
