I’m looking for a reliable and fast way to know if an external file has updated. I’m having the same issues as this older thread: How to watch/synchronise a folder? I’ve looked at three methods, method 1 works reliably but can be slow on larger files:
- File Path to Read File (set to Total File) to some null checking incase the file doesn’t exist. Slow for larger files
- Use the synchronize attribute on the File Path component, doesn’t work at all, seems like a bug
- Some sort of python or C# to watch the file, I can’t get these to auto update like FileSystemWatcher that the Read File component seems to use.
Ideally, the solution is always watching the file and doesn’t need a grasshopper trigger to update. Any help is appreciated.
Sample file (you’ll need to hook in a text file or something on your end):
File Update.gh (13.2 KB)
