I’ve noticed that V7 isn’t able to extend surfaces that were previously trimmed in any way. I have to untrim every surface before it can be extended. Check out this video to see how V6 worked well on the exact same surfaces that won’t extend in V7:
Here is the file if anyone wants to test it themselves.
Hi @Pascal, @DanBayn, I’ve also noticed that I cannot extend large amounts. Only baby steps: smaller amount in one take, and they extending again another smaller amount to reach my larger amount. Have you all noticed that too?
Yes Gustavo, I noticed it too. The command should be revised, sometimes it seems that it does not extend, as if it gets jammed, it is not very fluid in the extension operation.
(If the surfaces are simple and flat, the command generally works well; if the surfaces are curved, problems of little fluidity of extension begin).
