extendSrf fails on one edge ok other
V5
I need to extend surface the edge where indicated to get intersect line to then offset that line 0.3 and a 0.2 at the end area.
I used ExtendSrf on the top edge ok, and did intersect then offset that 0.2 entire length.
si then repeat that for the bottom edge, needs 0.3 and a 0.2 aft of the arc.
I use ExtendSrf again.
all I get is a ‘quiff’', at the far end !
extendsrf fail.3dm (273.7 KB)
why wont it evwen stick out beyond the brown as the other did ?
Cheers
Steve
