ExtendSrf gives bad shape in the other end of extend surface
Once extended edge on the other side gets distorted (if Merge option is yes) which seems to be default.
extendingSrf_error.3dm (128.6 KB)
Thanks, I see this as well. For now, to work around - DupEdge that lower edge, Untrim , ExtendSrf the other end and Trim again at the lower edge.
https://mcneel.myjetbrains.com/youtrack/issue/RH-44977
Seeing lots of fails with ExtendSrf here too, mostly where the edge extends the wrong direction.
Eric
Will be great if you share the examples that fail.
