I was trying to make a fork into an actual object using the extrude planar surface command but it keeps telling me its unable to because it will make an invalid surface. What do I do? How do I fix it?Section 10.3dm (325.8 KB)
Your question is very difficult to answer without more information. Which specific command are you trying to use? _ExtrudeSrf? With the surface visible run _SelBadObjects. Are any bad objects selected?
If possible post a .3dm file with the surface you are trying to extrude. You can drag the file to where you type a post, or you can use the verticle arrow icon above where you type a post.
I select the fork and I try to use the extrude planar surface curve straight command.
