Expression -- horizontal scroll bar
if using the Expression component and your formula is longer than the entry field, a horizontal scroll bar appears…
the scroll bar intrudes into the entry field so you can no longer see all the text (commas are hidden etc.)… (well, you can scroll the field vertically but then the top parts of the text starts getting cut off)…
(workaround – drag editor window out far enough to no longer need the scroll bar)
Thx! https://mcneel.myjetbrains.com/youtrack/issue/MR-2558
This should be fixed in the next RhinoWIP.
