Hi All.
I noticed that rhino 7 fails exporting the texture mapping when I export in obj format.
rhino simple box
max viewport
reimporting the obj in rhino
How is it possible?
I have the same issue…
No news here?
c’mon guys, i expect an answer and fix soon …
Hi all- the texture needs to be in the same folder as the obj and mtl files. The mtl file does not keep a path to the texture -
Hmm - that may not be it - Rhino does leave a copy of the texture in the export folder - still investigating…
@Pitti - if you edit the texture after reimporting to Rhino and set the mapping and repeat or size to be the same as on the original exporting file, does the texture show up?
