Edit: Just noticed a related post, Export STL - object name
Hi David,
Actually there is a way, but only by using the ASCII STL format. These get big fast as they are plain text not binary, but if preserving naming is key it’s a great simple format. When reading multi-solid STLs, Rhino builds a mesh for each solid and assigns the appropriate name.
Check out the first section of this article:
STL (file format) - Wikipedia
Here is a simple example:
The actual STL would look like this (“multisolid.stl”):
solid Triangle01
facet normal 0.000000000000, 0.000000000000, -1.000000000000
outer loop
vertex -9.778951644897, 2.685768365860, 0.000000000000
vertex -6.060195446014, 9.847817420959, 0.000000000000
vertex -1.928243994713, 3.856487989426, 0.000000000000
endloop
endfacet
endsolid Triangle01
solid Triangle02
outer loop
vertex 3.925354003906, 1.928243994713, 0.000000000000
vertex 7.644110202789, 9.090292930603, 0.000000000000
vertex 11.776062011719, 3.098963499069, 0.000000000000
endloop
endfacet
endsolid Triangle02
solid Triangle03
outer loop
vertex -3.856487989426, -6.955451488495, 0.000000000000
vertex -0.137731716037, 0.206597566605, 0.000000000000
vertex 3.994219779968, -5.784731864929, 0.000000000000
endloop
endfacet
endsolid Triangle03
Here’s a snippet to get you started (error and bounds checking are horrible but I hope you get the idea).
def getAsciiSTLSolid(mesh, name):
Description: Returns a text fragment for a single mesh with the given name.
Call this for each mesh/'solid' then join and save to a text file.
Mesh: Rhino mesh (must be triangulated)
Name: Name of solid in multi-solid stl.
indent = ' '
tNormal = '%sfacet normal %12.12f, %12.12f, %12.12f\n'
tVertex = '%svertex %12.12f, %12.12f, %12.12f\n'
asciiSTL = []
asciiSTL.append('solid %s\n' % name)
for i in xrange(rs.MeshFaceCount(mesh)):
fv1, fv2, fv3, fv4 = [mVerts[v] for v in fVertIndices[i]]
asciiSTL.append(tNormal % (indent, norms[i][0], norms[i][1], norms[i][2]))
asciiSTL.append('%souter loop\n' % (indent*2))
asciiSTL.append(tVertex % (indent*3, fv1.X, fv1.Y, fv1.Z))
asciiSTL.append(tVertex % (indent*3, fv2.X, fv2.Y, fv2.Z))
asciiSTL.append(tVertex % (indent*3, fv3.X, fv3.Y, fv3.Z))
asciiSTL.append('%sendloop\n' % (indent*2))
asciiSTL.append('%sendfacet\n' % indent)
asciiSTL.append('endsolid %s\n\n' % name)
if len(asciiSTL) > 0:
return ''.join(asciiSTL)
else:
return None
