Exporting drawings doesn't look as they should
Hi! I went to export my drawings, but then it gets swallowed up by some dark lines that I cannot see in the actual drawing.
I´ll attach how it looks in Rhino vs how it gets exported. It is the same for all my drawings and views when exporting.
Section final.pdf (55.5 KB)
Hej Miranda -
You’ll get better help when you attach the .3dm file instead of images or PDF files. There are a lot of possible combinations of different settings that are impossible to find out of from those files.
That said, importing your PDF file back into Rhino shows that this is some issue with print width scaling of possibly some fonts.
As you can see in that image, the selected curves have a print width of 150 mm.
