" In this different situation, the two boxes have different coordinate systems, so one has to transformed into the other. Also consider below that the maximum and minimum points of the section box are not enough alone to properly frame the section box with a crop box. If you transform P1 and P2 below from the coordinate space of the section box into the coordinate space of the view, you would end up with the red box. You need to know the missing corners; then you can transform all of the eight corner points into the coordinate space of the view. You then find the max/min XYZ from those and set crop box to green rectangle"
Ctu6, Use the bottom output of the bounding box. The tops the oriented (to view plane) the bottom output in the non-transformed box which will crop the view correctly.
Hi @Japhy at the moment I want to thank you in advance, I appreciate all your help these days.
The result turns out really great and provide solid information.
Right now our team is shooting for final DD submission by the end of this month, so have to hop on other things real quick … I’ll get back to the thread sooner the crazy stuff goes out.
Now you can specify the ‘Crop Extents’ and show only certain elements on each capture.
There is a ‘Template’ input also in case you want to take several shots using different view template applied.
Optionally you can postprocess the capture and generate one with a transparent background from the context menu.
