Export to dxf with export options
I need to export grasshopper output as a dxf but the components I know of do not enable selection of the export options. The export components I’ve tried convert curves to polylines, id like to export as a scheme where the curves stay as curves.
Any ideas?
I am using Elefront/Export Generic component to export DXF files with my own preset. First you need to create your own export scheme and after use that scheme name as S input in the Export Generic component.
Thank you for your reply which is appreciated.
I looked at this component, if I am right it can only reference with the id objects within Rhino, what I’d like to do if possible is save the grasshopper output automatically to a file.
I can do this with TTToolbox “CAD Out” component but the dxf export scheme converts curves to polylines and I cant see how you could set the export scheme.
Without baking geometry from Grasshopper to Rhino you can currently only save to a 3dm file.
I’m using the Grasshopper Rhino components in Rhino 8 to bake geometry and then a script to export to various formats.
In case of being interested I wrote this script some time ago
Regards!
Thank you, I will give this a try
