I have a problem exporting partgeometry from a tree.
I intend to export each partgeometry into separate pdf or dxf files.
There is a tree for the part geometies. Ecah oartgeometrise stored in different brances
(imported from theyr layers by elefront node).
Problems:
1.
For each “export instance” appears the file export options windows, and I have to confirm the exports manualy.
I used ExportAs of Plugin Pancake. Everything fine. I imported multiple files with “import3DM” component in Grasshopper. After that I managed some stuf and exported each file with ExportAs of Plugin Pancake.
Thank you for your proposal!
In case there will be no solution with GH Rhino8 and Elefront 5.15 I will follow your proposal. (In the company we try to minimise the number of applied plugins.)
I used EleFront in the past but since I’m also trying to minimize the use of plugins I’m now using a slightly modified script which @Helvetosaur posted. It exports the content in the Rhino file based on the object name.
I tested the ‘elefront’ export node, and the export of DXF files works as I envisioned. Unfortunately, I cannot use it for exporting PDF files. It may be necessary for our documentation office to find a solution for the automatic batch printing of DXF files.
