hey i wanted to ask if there is an easy way to save my gcode as text format on my desktop. So far I always use “Copy Data only” from my panel and then have to save it as a text document manually. Is there a plug in or a way to specify everything beforehand where and as what it is saved and then you only have to press a button or set a Boolean toggle to True and it is then automatically saved on any desktop, for example? I’ve also thought about the plug in elefront, but I’m not sure how to do it.
Hi @Yannic1,
you can use these:
