The latest version of the ShapeDiver plug-in includes a set of components that will help you set up and export PDF files either locally or online via an online application built with ShapeDiver.The tools are divided into two categories:
- First, the ShapeDiver version of the Squid plug-in was extended to let designers build PDFs like they can build bitmaps using Squid. Most instructions work the same way.
- Second, they have added some tools to the ShapeDiver plug-in to split, merge, internalize, and export PDF files inside Grasshopper.
Best of all, you do not necessarily need a ShapeDiver account (though it is free) to benefit from these components as you can use them locally in your machine.
Posted Jun 30, 2020 by Carla Sologuren on Rhino News, etc.
