Export Model Block Definition broken?
Can someone with the latest Rhino 9 WIP please check whether the Export Model Block Definition component works? I’m having trouble exporting with a definition that worked two weeks ago.
Yes, I am also seeing some problems.
But to make sure we have this covered:
  1. Can you give me an example?
  2. file type?
  3. Are you selecting existing blocks, etc….
I will start putting together a YT issue to track it.
Thanks @scottd
Here’s a simple example:
I tried *.obj, *.stl, *.step, *.stp and *.ply. which is not supported.
export-fail.gh (11.5 KB)
System Info
Rhino 9 SR0 2025-9-23 (Rhino WIP, 9.0.25266.10145, Git hash:master @ 20b4067c1882a571b5304975d8b2385b4678fada)
License type: Commercial, build 2025-09-23
License details: Cloud Zoo
Expires on: 2025-11-07
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 128GB)
.NET 9.0.9
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA RTX A5000 (NVidia) Memory: 24GB, Driver date: 8-21-2025 (M-D-Y). DirectX(11)
Secondary graphics devices.
NVIDIA Quadro K2200 (NVidia) Memory: 4GB, Driver date: 8-21-2025 (M-D-Y).
- There are no monitors attached to this device!
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.29 DYNAMIC_ARCH NO_AFFINITY Zen MAX_THREADS=64.
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.25266.10145
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 9 WIP\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.25266.10145
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.25266.10145
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.25266.10145
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\import_STEP.rhp “STEP Import”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.25266.10145
C:\Program Files\Rhino 9 WIP\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 9.0.25266.10145
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.25266.10145
C:\Program Files\Rhino 9 WIP\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 9.0.25266.10145
C:\Program Files\Rhino 9 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 9.0.25266.10145
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
Thanks, we will take a look.
Without getting fancy, I tried *.3DM and see problems.
When will this be fixed?
It has been fixed
I am seeing the same behavior today, this time in Rhino 8, in a definition that was working just fine last week. It’s not letting me save a file using the Export Model Block Definition. I am using Rhino 8 SR24 (8.24.25281.15001, 2025-10-08).
exportTest.gh (10.5 KB)
Simple example attached. Any idea what I am doing wrong?
Does the folder exist?
And maybe you need to update.
It works here in 8.25.25294
System Info
Rhino 8 SR25 2025-10-21 (Rhino 8, 8.25.25294.11001, Git hash:master @ dbd34d09714449d20e5a207d4433f62e2963f282)
License type: Commercial, build 2025-10-21
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 128GB)
.NET 8.0.21
Primary display and OpenGL: NVIDIA RTX A5000 (NVidia) Memory: 24GB, Driver date: 9-22-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 581.42
NVIDIA Quadro K2200 (NVidia) Memory: 4GB, Driver date: 9-22-2025 (M-D-Y).
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-22-2025
Driver Version: 32.0.15.8142
Z-Buffer depth: 24 bits
Total Video Memory: 24564 MB
C:\Users\martinsiegrist\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.25.25294.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.25.25294.11001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.25.25294.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.25.25294.11001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.25.25294.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.25.25294.11001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.25.25294.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.25.25294.11001
The folder does exist (I tried a few different filepaths just to make sure), but updating fixed it!
I’m not sure if it was the process of updating repaired something, or if there’s a fix in the latest version, but either way it’s working for me in 8.25.25294. Thanks!
As far as I understand, there was a fix in the latest update.
