Export mesh as for solid instead of surface only
I am starting to learn Rhino and really confused with simple problem. How do export a body in Rhino as solid mesh rather than just exporting the surfaces? I am exporting the selected as STL, when I check the STL it only has surface and inner part is not meshed.
Hello- if a mesh - or surface/polysurface or SubD - is closed, in Rhino, it is solid.
Thank you for your response. It looks solid in Rhino, I checked suing the clipping plane. But, still the STL file is just outer surfaces like the second picture.
Hi Nava - that is correct and normal expected behavior for stl - however printers will read the objects as solid if they are closed.
That’s what “solid” is in ALL 3D software, an enclosed volume. There is no math describing what’s inside. Except for voxels, but they’re also not really ‘solids’ but a cloud of points.
Thnak you very much. How about if I want to export the mesh for FEA, my models are self-intersecting sweeps. This causes problem when I try to import those files as STEP so I was trying to import as mesh.
Hi Nava - you may be able to use ShrinkWrap in the V8 beta.
Thank you, I will try it.
This is great, it improved my model a lot. The mesh in self intersecting part look great. My last concern is how do I export the mesh (or other supported format like STEP or IGES) so that I can use it for FEA in Abaqus?
