Hi, i am trying to create a c# method that will get all objects from a layer and its sublayer and will export to a new 3dm file keeping all attributes, etc…
What is the appropriate method to add objects to a file3dm?
Do I have to go through all type of geometry? like below:
switch (objectType)
case ObjectType.Brep:
Brep brep = geometry as Brep;
file.Objects.AddBrep(brep, attributes);
break;
case ObjectType.Curve:
Curve curve = geometry as Curve;
file.Objects.AddCurve(curve, attributes);
break;
default:
return false;
Is there a faster approach to duplicate layers with objects and attributes to a new 3dm file?
public static void ExportLayerAndSublayerGeometry(string layerName, string outputFile)
// Find objects in the layer and its sublayers
var objects = FindObjectsInLayerAndSublayers(layerName);
if (objects.Count == 0)
// No objects found
return;
// Create a new Rhino document based on a template file
var newDoc = RhinoDoc.Create("Large Objects - Inches.3dm");
// Get the object table from the new document
var objectTable = newDoc.Objects;
// Create new File3dm
var file3dm = new File3dm();
// Add the objects to the new document and the File3dm
foreach (var obj in objects)
var newObj = obj.DuplicateGeometry();
var attributes = obj.Attributes.Duplicate();
// Add object to newDoc
objectTable.Add(newObj, attributes);
// Add object to file3dm
file3dm.Objects.Add(newObj, attributes);// not working here!
// Save the new document to the specified file path
file3dm.Write(outputFile, 5); // 5 represents version 5 of the Rhino 3DM file format
