hello there, I want to make some kind of a database, but with rhino files. So,for example, in the current Rhino file I create 2 objects. When this custom command is executed, it should select the 2 objects, loop thru them, and then save them, or export them, INDIVIDUALY in a .3dm file, at the path that I want. Eventually, I’m thinking to save the .3dm file with the object GUID for a better control. I have all the puzzle’s parts in my mind, but only the export part is unknown.
So, in conclusion, I need the python command which exports objects, and the way to create the empty 3dm file
You can also take a look at my code here for a rather fast Python OBJ export:
It’s meant for Grasshopper to export sequences of OBJs for animation purposes - basically like you would export rendered frames for a video -, but it should also work for single OBJ export in Rhino. It probably only needs some minor modifications.
