Export/import Document Properties
I’m trying to make Rhino inside Revit the same as regular Rhino. Even if I open the same template file, the Document Properties aren’t copied over at all. I’ve modified Document Properties, and it would be quite a bit of work to match it one by one.
Is there an option to export/import Document Properties?
Hi L -
All document properties are saved in the 3dm file. We’ll need more specifics to understand what is going on here…
Hi L,
If i understand correctly you are looking to open the same template.
Is this option checked?
Yes, that option has been checked on.
As an example, View properties are not copied over even though I opened the same Template file that I use for regular Rhino, as shown in the screenshot. On the right side of the screenshot, the regular Rhino View in Properties has quite of modifications, but Rhino inside Revit doesn’t show any.
Also, Keyboard macros are not copied over. I can export and import Aliases, I didn’t find a way to do so with the keyboard macro?
Another example is, I use the mid button for rotate view. Rhino inside Revit doesn’t do so. This particular one is an easy click in Document Properties, but there are so many settings that aren’t the same. That made me wonder if I was missing some sort of export/import Document Properties, like Window Layout / Aliases.
I actually did go through every single setting in Document Properties when I upgraded to Rhino 8 in order to match what I had in Rhino 7, and every single second was frustrating. I felt so incredibly stupid, dumb, moronic trying to match Document Properties. I’m trying to avoid the same self hatred.
Everything works as expected here.
Steps to repeat:
  1. Be in Rhino.Inside.Revit & have isolate options option checked.
  2. Create a new template file with your alterations
  3. Check Use this file when creating new file.
  4. Close the Revit instance.
  5. Re-open and verify.
Do you mean to say, I need to alter Document Properties In Rhino inside Revit again and save it as a new Template? That’s exactly what I’m trying to avoid. Rather, I’d like to use the same Document Properties from regular Rhino that has already been altered.
Sorry if I’m still missing something.
Does unchecking isolate settings work for you?
will try ‘unchecking isolate’ later and report back.
No. It didn’t work.
I opened the same Template and imported Window Layout, so it all looks the same as my regular Rhino. However, Rhino inside Revit does not copy over any Document Properties. All View options are left as default.
Ensure isolate settings is not checked, close Revit - Revit, navigate to this folder and delete the file, restart revit.
C:\Users\YOURUSERNAME\AppData\Roaming\McNeel\Rhino.Inside\Revit\1.0
No, it still does not do it.
I opened a file that was saved from the regular Rhino, but Rhino inside Revit refuses to copy over Document Properties.
Actually the xml file needs to be there to hold the do not isolate files setting.
@Japhy Thank you for your patience and help. It finally worked.
