when using Rhino 6 on an Apple computer the Hi-Res image export is cropped in a very strange way. Just close to the extents of the Grasshopper setup, the components are cut. This does not occur on Windows.
Does anyone know how to solve this? We’ve trying to find the reason for a while now…
Hi, I have exactly the same issue with Rhino 7 on my an Apple M1 laptop. Not sure if you figured out how to solve this? I couldn’t find the solution to this answer anywhere else other than this post.
Dear @karen0317lin@Mandi_Blanton@SFS
Did you ever found out how to get Hi-res Images working with the correct cropping / section ? is it still a Bug ?
(.EDIT… I would claim yes - works as expected on Windows)
I do not get a cropping that makes sense in both v7 and v8 under mac os x 13.5.1 (22G90)
Rhino:
Version 7 (7.37.24004.15002, 2024-01-04)
and
Version 8 (8.6.24101.05002, 2024-04-10)
I just tried the following on a reasonably large definition:
If I export high res when zoomed it, I get a cropped result
If I export high res, after zoom extents, I get a correct result.
The part with, "after zoom extends, I get a correct result…
It used to work perfectly for me, but I think since I updated my rhino7 it doesn’t work anymore.
