Export C++
I used to call the exporter from python. Now I’m porting the code to C++ but nothing happens.
Here is what I do:
	unsigned int rhino_doc_sn = context.m_doc.RuntimeSerialNumber();
	CRhinoObjectIterator it(
		rhino_doc_sn,
		CRhinoObjectIterator::undeleted_objects,
		CRhinoObjectIterator::active_and_reference_objects
	for (CRhinoObject* rhino_obj = it.First(); rhino_obj != nullptr; rhino_obj = it.Next())
		rhino_obj->Select();
	context.m_doc.Redraw();
	ON_wString script;
	script.Format(L"! _-Export \"%ls\" _Enter", filename.Array());
	RhinoApp().Print(script + "\n");
	RhinoApp().RunScript(context.m_doc.RuntimeSerialNumber(), script);
If I copy/paste the command I print directly in Rhino, it works, but if it’s done through RunScript in C++, I only get “Command: _-Export”, no progress bar, no file created.
I tried other type of file with the same result.
I tried the CSampleScriptCancelHelper and it returns success.
Thanks!
– Paul
Have you made the command able to run scripts? You should inherit from CRhinoScriptCommand, see
You solved it!
Thank you so much.
– Paul
