How to use Rhino "_Export" command through in c#?
After the code logic runs, I’m trying to call the rhino “_Export” command to export the currently selected objects, but the save dialog doesn’t appear.
I need the save dialog to appear.
            bool foundObjectsWithoutCWName = false;
            var selectedObjects = doc.Objects.GetSelectedObjects(false, false);
            var selectedObjectIds = new List<Guid>();
            foreach (var obj in selectedObjects)
                selectedObjectIds.Add(obj.Id);
            if (selectedObjects == null)
                return Result.Nothing;
                if (obj == null)
                    continue;
                var attributes = obj.Attributes.Duplicate();
                if (attributes.GetUserString("Test") == null)
                    var layerName = doc.Layers[obj.Attributes.LayerIndex].Name;
                    attributes.SetUserString("Test", layerName);
                    obj.Attributes = attributes;
                    obj.CommitChanges();
                    foundObjectsWithoutCWName = true;
            if (foundObjectsWithoutCWName)
                doc.Views.Redraw();
            RhinoApp.RunScript("_Export ", true);
            return Result.Success;
Hello, have you read the following link?
[Rhino.Commands.CommandStyle(Rhino.Commands.Style.ScriptRunner)]
public class TestCommand : Rhino.Commands.Command
Thanks
