I have a need to exit the Rhino process from a C++ plug-in, but when I call
RhinoApp().ExitRhino();
in my code, the linker complains with
My question is: can I exit Rhino from C++ code, and if so, how?
RunScript with "_Exit"
No, I mean unconditional exit - user should not be able to press “Cancel”.
I’ve solved it by using a callback function pointer to .NET code, where I can call RhinoApp.Exit()
. Plus it is easier in .NET to show the user some dialogs & ask them to save their work before the exit.
Hi @menno,
CRhinoApp::ExitRhino()
is not a publicly exported function, thus the unresolved external symbol error.
You might try one of these:
C#:
public class QuitCommand : Command
public override string EnglishName => "Quit";
doc.Modified = false;
PostMessage(RhinoApp.MainWindowHandle(), 0x0010 /*WM_CLOSE*/, 0, 0);
return Result.Success;
[DllImport("User32.Dll")]
private static extern bool PostMessage(IntPtr hWnd, uint msg, int wParam, int lParam);
C++:
CRhinoCommand::result CCommandQuit::RunCommand(const CRhinoCommandContext& context)
context.m_doc.SetModifiedFlag(FALSE);
::PostMessage(RhinoApp().MainWnd(), WM_CLOSE, 0L, 0L);
return CRhinoCommand::success;
– Dale
