I believe there is an issue with rs.ExplodeBlock() in rhino6. I have a block instance containing an object with object attactched user text (see .3dm the rectangle), if I run the following code snippet to explode the block, the usertext is lost. I expected it to be in the resulting objects as well, like when I run the command ‘Explode’
objs = rs.GetObjects('select')
if objs:
for obj in objs:
result = rs.ExplodeBlockInstance(obj)
Hi Tim, thanks, I’ll take a look. I have a feeling I already made a bug report and a workaround for this, I’ll see if I can find it.
Yeah, found it… @timcastelijn - see if this helps for now:
import scriptcontext as sc
import Rhino
def ExplodeBlock(thing,instance_xform):
expStatus = True #check for failure so I know not to delete the input object
xform = thing.InstanceXform
# if this is looping through nested blocks there will be
# an incoming transgform to take into account
if instance_xform:
xform = instance_xform * xform
inst = thing.InstanceDefinition
objList = []
# get all the objects in the definition
for i in range(inst.ObjectCount):
temp = []
x = inst.Object(i)
objList.append(x)
# look through the definition objects and send them back
# through if they are instances themselves,
# else, apply the accumulated transform, the attributes and
# put them in the document
for n in range(len(objList)):
if isinstance(objList[n], Rhino.DocObjects.InstanceObject):
ExplodeBlock(objList[n], xform)
else:
geo = objList[n].Geometry
geo.Transform(xform)
new = sc.doc.Objects.Add(geo, objList[n].Attributes)
if not new: expStatus = False
return expStatus
def test():
id = rs.GetObject("Select a block instance.", filter = rs.filter.instance, preselect=True)
if not id: return
thing = sc.doc.Objects.Find(id)
rc = ExplodeBlock(thing, None)
if rc:
rs.DeleteObject(id)
sc.doc.Views.Redraw()
test()
